I just had a DVD writer and made some backup DVD's when using Pioneer it worked fine but when I use Samsung C621 5 disk it does not work at all.
Do you have any experience like? Please advice.
Thanks![]()
You didn't say what format DVD burner you use. Is it a +R or -R?
I have a Samsung C631P 5 disk player, which is very similar to yours.
I burn using an Aopen DRW4410 +RW burner. ALL the disks I make work perfect on my Samsung (+R, +RW).
However, this was not always the case. This is because initially I used NERO 6 to burn my DVD's. BIG mistake.
After getting some help here, I decided to try Stomp's RecordNow MAX.
That fixed EVERYTHING.
Also, I use DVDINFO PRO to change my booktype settings to DVD-ROM.
However, my discs play even when burned as DVD+R(W)
So, perhaps your problem lies with the software you use.
Don't give up, you will eventually find the answer.
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 11:45 -
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 10:34 -
Samsung BD-P1590 VS Samsung BD-P1500?
By Darkerknight123 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 3rd Jan 2010, 17:51 -
Samsung HT-Z210, Samsung HT-X250
By emmy207 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Mar 2009, 23:06 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42
