I have a multiplexed m2v file created and would like to know what I need to do next in order to create a DVD image so I can burn in Roxio Toast.
This was a file created from a raw .dv file converted to and m2v file.
Do I need to split the audio and video in order to create the image?
(Using a Mac)
Use IFOEDIT to create VOB,IFO,BUP files then use BurnatOnce to burn(unless Roxio can burn VOB files).
Read:https://www.videohelp.com/forum/userguides/120013.php -
a m2v file is video only. But I would use either IFOEdit to create a DVD file structure or use TMPGEnc DVD Author to do the same thing. You will need the audio file reguardless of which method you use. Then when you have a Video_ts directory on your computer just use any burning software to make a data disc and have it put the Video_ts directory on the disc, you need the directory and the files in it, not just the files in the directory.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 09:13 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 05:09 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
