Hi all
Could you please give me your valued help one more time?
My purpose is simply to convert an avi file to CVD in order to watch it in my standalone player.
But for some reason my product is a very jerky video with a quite fragmented audio.
I have checked my procedure an settings but I couldn't find what is wrong, a clue from you would be very useful.
That is:
Source file :
DivX Pro 5.05 VBR
512 x 272
23,976 fps (ntsc film)
audio MP3 VBR
Intended file:
Mpeg2 VBR
352 x 480
23,976 fps w 3:2 pulldown
audio MP2 160 kbs VBR
Procedure:
1. Open VirtualDub, load the avi file
2. Extract audio (PCM uncompressed) to wav
3. In direct stream copy I save the avi (only video)
4. Open TMPGEnc, load the avi (video) and wav
5. Video main Settings :
size: 352 x 480
aspect ratio: 4:3
frame rate : 23.976 fps (internally 29.97 fps)
rate control mode : 2 pass VBR, avrg bitrate 2100
video format: NTSC
encode mode: 3:2 pulldown when playback
motion search precision : high quality (slow)
Ok, in fact I don't burn the movie, I check the resulted MPG it in BS Player and in Windows Media Player, all my tests failed.
Please , I'm waiting for a tip.
I think that might be your problem as regular Vdub doesn't handle VBR-MP3 audio very well. Did you get the VBR pop-up warning? Try a different way to create your wav file. I prefer Goldwave as it handles most audio types including AC3, just load your avi and save. You can try AVI2WAV or Virtualdub-MP3 as well.Originally Posted by HDSN
BTW, you don't need to create an avi without audio. Just use your original avi for the video source.
You did scan for bad frames, right? If not then click my link below."Art is making something out of nothing and selling it." - Frank Zappa -
I would do the following:
1) I would use my CVD template off my site
2) Open TMPGEnc, use my CVD VBR template, load the avi
3) rate control mode : 300min 2100avg 2520max
This is what I've done in the pastEjoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
when testing use motion search precision fast. Do only 3 mins range then check the result. CVD may not be compatible. Defrag your hard disk. Reboot PC. Closedown unnecessary programs. dont use bs player to play mpgs. use a cdrw, someteimes choppy on pc comes out alright on player.
why not vcd? quicker & more compatibleCorned beef is now made to a higher standard than at any time in history.
That's very possible, your machine just might not like it.Originally Posted by RabidDog"Art is making something out of nothing and selling it." - Frank Zappa
Thank you all
I will follow your suggestions and I'll be back soon!
Of course ZippyP, lets optimize our time!Originally Posted by ZippyP.
Right RabidDog, useful hint!Originally Posted by RabidDog
CVD may not compatible with what? standalone player?
Better quality !Originally Posted by RabidDog -
Hi again
I made some tests with the same source file applying SVCD NTSCfilm 2100 CBR and standart VCD NTSCfilm templates on TMPGE.
First I checked for bad frames in VDubMod, it was ok.
I extracted the audio with Goldwave.
result :
VCD : audio and video synchronized, but video was a little jerky
SVCD: nothing changed. The same problem described before.
It seems to be a mpeg2 question, right?
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 23:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 08:55 -
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 13:13
