I just purchased a LG GSA 4040B. ($189 CDN) I bought it thinking I could transfer my 200+ VCD library to DVD and then only have 25-30 DVD's.
If anyone can direct me to a guide, or tell me if I am even able to do this, it would be greatly appreciated.
Also, some useful software suggestions would be nice. I have no idea what will work well for DVD's.
Thanks!
Use VCDGear or ISOBuster (freeware) to rip the VCD .dat or .bin to mpg, then use TMPGEnc DVD Author or DVDLab (trialware) to author the DVD as 1 mpg per title. Should be able to do 8 to 10 VCDs on 1 DVD.
Beware there is a bug in TMPGEnc DVD Author when one tries to author long mpg files as chapters, sometimes it freezes during playback. It is best to author mpg files as titles, and pick "play next track after finishes" setting for the menu. -
Don't think so, a VCD is 800 MB, a DVD is 4.3 GB. You can get 4-5 VCD's on a DVD.Originally Posted by xcool
There's lots of guides for VCD on DVD, like here.. For maximum compatibility the audio needs to be changed as the sampling rate spec. for VCD is 44.1 KHz vs. 48.1 KHz for DVD. The MP2-VCD audio is not NTSC-DVD compatible as well, although it is for PAL. Many people prefer to leave the audio as is and have no problems, it really depends on your DVD player and how compatible you want your videos to be.
Good luck."Art is making something out of nothing and selling it." - Frank Zappa -
Ooops,
ZippyP you are right that if "a VCD is 800 MB, a DVD is 4.3 GB. You can get 4-5 VCD's on a DVD", I can do 8 to 10 VCDs on 1 DVD because my TV series VCDs are 400 to 500 MB.
If you use TMPGEnc DVD Author, it automatically re-encode the audio to 48.1khz if the audio is 44.1khz, which is why I use TMPGEnc DVD most of the time now. Also for VCDGear, use "Correct MPEG Error" if converting from VCD .dat. -
So if I've got the mpeg files saved on my HD, how do I get them onto DVD and watch them as a VCD? I have the whole second season of 24 that I really want to watch.
I've downloaded most of the programs suggested. -
Go to the "Guides" section on the left hand side of this page, select the format conversion box and select VCD to DVD from the list, select search for guides, a list of guides for doing what you want will appear, pick a guide.Originally Posted by hulkamania"Art is making something out of nothing and selling it." - Frank Zappa
I used TMPGEnc Plus to rip an mpeg..... I'm not really sure what exactly I did, but now instead of it being 490megs, it's now 1.3 gigs.
google maps adds biking directions
By deadrats in forum Off topicReplies: 3Last Post: 12th Mar 2010, 19:59 -
Best Software to Edit VOR & IFO Files from Panasonic RAM Disk & Arc
By JDex in forum Newbie / General discussionsReplies: 16Last Post: 30th Sep 2009, 06:55 -
Asafs TV Episodes to VCD-DVD guide
By angelheart in forum User guidesReplies: 4Last Post: 19th May 2008, 21:47 -
VirtualDub MSU Subtitle Remover directions help
By LangleyM in forum SubtitleReplies: 4Last Post: 6th Feb 2008, 08:56 -
I need a guide to convert avi to dvd plz (newbie topic) help
By Death009 in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 08:03
