I recently purchased a 24" True-Flat RCA TV/VCR/DVD combo unit from Sam's. I really like the unit. It has great picture and sound - especially with the DVD. I do have one gripe, however. The box said that it supported DVD, CD, CD-R, CD-RW, and MP3. With this in mind, I thought that it should be able to read VCD/SVCD's as well since they are on CD-R media. Sure enough, when I got it home and inserted a VCD, the unit replied "Incorrect Disc". After trying several VCD's and SVCD's and upon closer reading the manual, I found one line which states that Video CD's are not supported with this model.
Is it really so hard for a manufacturer to make a DVD player that supports all of the common formats?!? If anyone here knows of a firmware update or possibly a "Service Menu" fix that would allow me to play VCD/SVCD's on this unit, I would appreciate your reply.
Thank You,
Jay
Its all pretty much in the software that the manufacturer uses in the dvd player and yes you would think the software that picks up more formats than the standard dvd/mp3/cdr is more expensive but i just picked up an Apex 1225 for 34.00 and its played everyformat ive thrown at it (over 9 so far) so go figure!
Best Dvd Recorder/Vcr Combo
By rosbif08 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 9th Oct 2010, 16:52 -
DVD/VCR Combo Player
By pepegot1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Feb 2008, 12:41 -
Help deciding for VCR/DVD combo
By UltW in forum Newbie / General discussionsReplies: 7Last Post: 2nd Oct 2007, 22:45 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02 -
Magnavox combo DVD/VCR/TV
By DSedon in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jul 2007, 12:36
