Im in the process of authoring a DVD using TMPGEnc DVD Author when i selct the 'output' button i get an error message saying the combined bitrate of the clip exceeds the upper limit for a standard DVD, it says it cannot guarantee it'll play on a DVD player and to check the maximum supported bitrate of my player. I was just wondering if this is likely to be a problem, do most DVD players have a limit of 9.848Mbps or will it play on most DVD players?
Results 1 to 9 of 9
That's Video+Audio, and it's an odd rate. It's supposed to be 9.8 Mbps sustained forever, but it's also a peak. It's based on the minimum speed your DVDplayers drive can do. Try it on an RW and see how it plays? My player isn't too sensitive to bitrates.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
It plays fine on my DVD player but im wondering how much of an issue this would be. In general would this be a problem for most DVD players?
As a general rule, for recordable DVD media, it is often advised to keep the max bitrate somewhere below the DVD specification. The reason for this being that most DVD players find recordable DVD media 'harder' to read (more errors and retries) due to the lower reflectivity of the disks. If you keep the max Video bitrate to around 8K and audio around 384 or less you should be fine.
How do i reduce the bitrate? I used DVD decryptor on a DVD of mine and its bitrate was 9800 plus the audio taking over the limit. How do i reduce the bitrate?
You set the bitrate when you encode the mpeg. How you set it depends on what encoder you used. If you acquired your mpegs already encoded then that is a different matter.Originally Posted by Alias75
Yeah the mpegs are already encoded at 9800. Plus the audio, when i ty and author with TMPGEnc DVD Author i get an error message saying the combined bit rate exceeds the upper limit of a standard DVD. It plays on my DVD player but i was just wondering how much of a problem could this be with other players? And why is it over the limit? Id dint change the files at all they where ripped at 100% using decryptor so why are they over the limit?
The total combined bitrate for video+audio+subtitles+overhead (navigation info etc) on a DVD should not exceed 10.08Mps. It seems to me that TmpGenc DVD author may be being a little conservative in its warning level and you are probably OK.
Yeah thats what i figured as other authoring software doesnt give the same warnings. Thanks for your help
Program to tell you the combined length of mp3 files?
By branch in forum AudioReplies: 2Last Post: 6th Oct 2010, 22:20 -
removing a combined frame.
By fred3f in forum EditingReplies: 11Last Post: 19th Jan 2010, 22:38 -
Best quality 30p to 24p workflow... mac, or combined with PC?
By joshcali in forum MacReplies: 11Last Post: 21st Sep 2009, 07:45 -
Combined DVD Movie with Deleted Scenes?
By Ghtpua in forum EditingReplies: 3Last Post: 25th Aug 2009, 20:34 -
Combined movies different Frames Per Second FPS
By lindylex in forum EditingReplies: 2Last Post: 4th Jul 2008, 20:33
