Hi all
I need some help to fix my tmpgenc plus suddenly not working at all. I try to uninstall and reinstall it again but it not working eigher. I need some help or advice what should I have to do.
win2k
pent 2.66
756 mega mem
Mentalo the mind reader might help you, anybody else needs details. every detail. in detail . Lots of detail. Like a murder investigation.
Read the guides first. 8)Corned beef is now made to a higher standard than at any time in history.
Without any details, I will take a guess. You loaded it 2 weeks ago without paying for it and it has timed out. It leaves something on you HD so that reloading is doesn't fix it.
If this is right, I am not sure that you can do anything other than register it - pay for it. Try setting your date back to the day you downloaded it. I don't know if that will work, but it's easy to try.
If this is not your problem, you will have to explain what your problem is. Just saying it doesn't work anymore is a good way to get ignored.
Start over with another post. They guys who know enough to help you may not bother to revisit a post with such a lame problem statement.
CUDA not working with TMPGEnc VMW 5
By indymudcat in forum Video ConversionReplies: 3Last Post: 29th Mar 2012, 13:33 -
TMPGEnc Authoring Works 4 input 264 not working
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 18th Sep 2011, 09:51 -
Tmpgenc has stopped working after 7 years of no problems
By Debibeanne in forum Video ConversionReplies: 17Last Post: 12th Mar 2008, 10:57 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 01:52 -
TMPGenc 2.5 not working in vista?
By yogart in forum Video ConversionReplies: 5Last Post: 7th May 2007, 01:37
