Hi all,
I searched on this topic and found that most people think this has to do with a field order mix up. I have an AVI file I captured on with Winfast TV 2000XP Deluxe card and I encoded using MainConcept in Premiere.
The only option relating to field order in Premiere's MainConcept is Lower Field First (DV), Upper Field First or No Fields. The default is Lower and is what I used to encode to MPEG. Should I have used Upper or No Fields since this wasn't a DV AVI? I have no idea what field order is or what it means to the final MPEG so any insight would be great. This jitter gives me vertigo.
As always thanks in advance.
EDIT - I did find this in the Glossary....In an interlaced video a field is 1/2 of a complete picture (Frame) consisting of the even or odd scanlines in the frame. Usually each field is labeled ie. Field A and Field B. When working with interlaced video it is important to note the Field Order (if Field A comes before Field B in the video stream) especially when encoding. If you notice flicker after encoding you will want to change the field order in the encoding template and reencode.
...I guess field A and B and interchangeable with Upper and lower fields? And how can I tell what field comes first?
Well I answered my own question by trial and (thankfully no) error. I adjusted the field order to Upper field (since the source was not DV AVI)and then re-encoded. I authored the DVD and it works just great. NO JITTER.
Hope this helps someone using Premiere in the future.
Jitter during transition in and out...
By Huntr777 in forum MacReplies: 18Last Post: 15th Jul 2011, 14:51 -
video with alot of horizontal jitter
By spiritgumm in forum Video ConversionReplies: 14Last Post: 24th Aug 2010, 14:35 -
"Encode video to audio duration" causes menu background jitter/no
By Fairy in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 8th Feb 2008, 17:02 -
Why Does One Mpg Jitter and One Doesn't? And Why The Jitter?
By abrogard in forum Video ConversionReplies: 10Last Post: 17th Nov 2007, 03:21 -
8500 GT Nvidia Video jitter
By boborg in forum Media Center PC / MediaCentersReplies: 0Last Post: 8th Jun 2007, 18:33
