    Nov 2003
    Anaheim, Ca.
    Hello all;My main reason for writing in this forum: I'm having trouble getting Imgtools to find my VIDEO_TS folder. Here is what I have done:
    1.In DVDShrink 3.0 Beta 5 I Opened Finding Nemo Disk and backed up, to G:\FINDING NEMO 2. I went to Explorer and opened G:\FINDING NEMO\VIDEO_TS folder and created another set of folders inside it (I'm not sure if this was the right folder to do this in, this is the first HELP I need) after making the folder I copied all of the files from G:\FINDING NEMO\VIDEO_TS to this new folder. I now have a path = G:\FINDING NEMO\VIDEO_TS\VIDEO_TS.
    3. In ImgTools 0.90 Build 8 the options are:
    A) Source Directory Mine is G:\FINDING NEMO
    B) Target Directory Mine is G:\PROGRAM FILES\IMAGETOOLS\TARGET FILES\NEMO
    C) Volume ID FindingNemo
    Upon clicking Image I get UKNOWN ERROR! [/i]
  2. try decrypting with DVD Decrypter first, then Shrink, then ImgTools. good luck.
    Dec 2002
    Well duh!!!!!
    Easy fix. Point IMG tools to the folder G:\FINDING NEMO\VIDEO_TS\ instead of G:\FINDING NEMO\ and it will work just fine.
    IMG tools must see the VIDEO_TS folder, with all the goodies inside. It automatically creates the empty AUDIO_TS folder. You should shrink into G:\FINDING NEMO\VIDEO_TS instead of G:\FINDING NEMO\VIDEO_TS\VIDEO_TS not quite sure how you managed that???
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
    Nov 2003
    Anaheim, Ca.
    Thanks Gaz;
    I'll try your suggestion! Also Do I need to creatE a second set of folders after the G:\Finding Nemo\VIDEO_TS and copy all files to it ??
    Dec 2002
    Do this:
    1)Make a folder on 'G' called NEMO
    2) In G:\NEMO make a folder called VIDEO_TS and AUDIO_TS (get in the habbit of doing it right)
    3) Shrink into the folder G:\NEMO\VIDEO_TS\
    4) Run IMG tools and point it to G:\NEMO . Point your ISO file to either g:\ or C:\ for more speed. IMGTools is obnoxiously fast going from 1 drive to another. It's slow going to the same drive. I reccomend calling it NEMO.iso, then in the third line make it NEMO so you can ID the disk in your computers drive.
    Nov 2003
    Anaheim, Ca.
    Gaz:
    I took all of the shrink files that were in g:\finding nemo\video_ts\video_ts and put them into this dir. G:\Finding Nemo\video_ts and removed the last sub dir. I pointed Img Tools to this dir. I now get can't finda video_ts directory. this directory musc exist below the source dircetory!
    MMMMMM
    GT
    Nov 2003
    Anaheim, Ca.
    Gaz:
    Here is where I got that second set of folders information and it was a bit confusing.....http://www.polarhome.com/~afonic/dvdxcopyxpress.htm
    go to the Img Tools and DVD Decrypter
    thanks
    GT
  8. http://www.mrbass.org/dvdshrink/AutoShrinkISO.zip
    I dont know if you are using this application, but it automates the tools that you are using now.
