The compatibility lists at Sonic for ReelDVD 3.0 show it works with the Sony DRU-500 DVD burner, but list no higher models. I know it works with some higher models that aren't on that list (such as the Panasonic DVR-106A, which isn't on the list, yet the 105A is). I'm thinking about buying a DRU-510 specifically to use with ReelDVD 3.0 but I want to make sure it'll work before I buy it.
Is there anybody out there with a DRU-510 that's used it with ReelDVD? It ships with Sonic's MyDVD, which is a good indicator, but I specifically need to use the drive with ReelDVD for functions it has that MyDVD does not.
Thanks in advance guys!
Jeremy Morrow
Hamilton, Ontario, Canada -
If you're really into ReelDVD and the DRU510, then go ahead with your purchase. You can always 'Create Image', or 'Create DVD-Video' in ReelDVD, for later burning using DVD Decrypter, or Nero (or whatever).
I just don't think you can do a straight burn to DRU510 via ReelDVD, since DRU510 is relatively new (in relation to ReelDVD's version).
my 2cents. -
Now that's some good advice. Thanks man, that's just what I'm gonna do. Didn't even occur to me to image the project and burn with another app (insert forehead slap here).
Jeremy Morrow
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Sony RDR HX 510 and DVP NS 305
By SearchQuality in forum MediaReplies: 10Last Post: 16th Nov 2007, 11:41 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 18:40 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 11:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
