Hi I've being making dvds for a while now, butI have not done vhs to a dvd format.I have just bought a tv card so I can capture my video, the trouble is when I try to convert it with Ulead Video Studio, it alway crashs before it is completed. It works if I only encode a little bit of the mpeg, but whe I try to encode a big portion of the mpeg say one and half hours worth to a title set on my hard drive it keeps crashing. Can anybody recommend another program for doing this ? or have any idea ho to get arround the crashing problem.
My computer spec is
athlon xp 1.7
pc chips 810 motherbord
half a of gig of ram
180 gig of hard disk space
winfast tv 2000 TV card
Have you installed any of the patches? If you did, you did not mention it or anything else you tried.
Hello. -
FAT32 or NTFS?
Turn your screensaver off.
Shut your virus scanner off(some auto scan when idle for a set time, idle is defined as no typing or mouse movements)
Free space? You can easily use triple the final result in scratch files.
Try CCE or TMPGEnc, both are superior encoders to Ulead.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I have installed force aspi17, and the anti virus screen saver and firewall are all switch off. I have a NTFS system.
converting from mpeg2 or wmv to a format for idvd or final cut express
By jbrown23 in forum ffmpegX general discussionReplies: 2Last Post: 8th Mar 2011, 22:23 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 10:23 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Need advice on converting MOD (mpeg2) files to usable format for iMovie
By InsanelyOne in forum MacReplies: 3Last Post: 9th Sep 2007, 16:23
