Can anyone tell me how to get the 'best' setting for a Divx conversion?
I looked through the bitrate calculators in the tools section and found nothing I thought would calculate Divx 5 properly.
I suppose what I am looking for is something that scans the original file and shows you what bitrate you need for a given file size and quality with quality being the most important setting.
R
There's no such thing.
The settings I use for a South Park capture aren't remotely related to a 1 Disk DVD encode.
Factors involved include, but aren't limited to:
1) Source quality
2) Action/Talking heads
3) Audio tracks (AC5.1 audio takes up a lot of space)
4) Animated/CGI
5) Length (2 minute clip or 3 hour movie), which often limits bitrate
6) Interlacing
7) single/multi pass
8) Quality versus size
and the list goes on.....To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Yes, I understand, but what is the bitrate tradeoff. I seems that I have read that the more bits you encode with, the slower your playback may be on some systems.
Is that still a relevent issue?
R -
That applies to PII and some AMD chips. You can't play a 2-disk DivX on a PII 333 in full screen. There's too much cpu processing.
If you have a 1 Ghz plus and a real hardware accelerated video card it's a non-issue. A lot fo the problems stem form post-procesing settings int eh DivX playback codec.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Confusion about DivX-Encoding settings
By foxhunter in forum Newbie / General discussionsReplies: 37Last Post: 23rd Jul 2009, 11:26 -
DVD to DivX - settings for better quality
By CodeMaster2008 in forum DVD RippingReplies: 11Last Post: 14th Jul 2009, 03:20 -
Recommended settings for dvd to divx ?
By jimcgr in forum DVD RippingReplies: 6Last Post: 11th Feb 2008, 07:25 -
Dr. DivX subtitle settings
By drstupid in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 07:13 -
Configuring settings when converting to AVI (DivX codec)
By firas_hashim in forum Video ConversionReplies: 15Last Post: 24th Jun 2007, 02:21
