  1. i was reading a guide on conversion of dvd to svcd using dvdx and tmpg....anyways i have a question
    1. (from the dvd-svcd conversion guide) why in the output settings of DVDx do i need to select "video server" in the premiere plugin box....this creates an .avs file for the movie output
    and then with the .avs file i i would have to use Tmpg to convert it to mpg.
    -i understand why i need to convert to mpg but my question is
    if i dont choose video server in the premiere plugin box i can can choose to save the output straight to a mpeg1/mpeg2 file
    i did it this way and the dvd conversion came out EXCELLENT!!! i didnt even need to use Tmpg(DVDx did everything)
    so why does it say in the conversion guide that i need to select the video server option and create an .avs file (then in which i must convert to mpg)
  2. Member Dhruv's Avatar
    Aug 2001
    Australia
    If you use DVDx to TMPGEnc using the video server, you get even better quality!,
    Dhruv bhatiadhruv@hotmail.com
    I only dream in black & white...
    MSN: paschendale@gmail.com
  3. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    does this method take longer also?
  4. Member Dhruv's Avatar
    Aug 2001
    Australia
    i think that the encoding time will be around the same for both methods...
