Hi,
I installed the demo version of Mainconcept DV codec also Huffyuv and i have the Pinnacle DV codec.
I'm trying to see the capture quality difference between the codecs.
How can i easily switch between the codecs when i capture. I use Premiere 6.5 and Scenalyzer Live.
Thanx
In Premiere select: Project->Project Settings->Capture
In the dialog-box that pops up select "VFW Settings..." and in the new dialog-box select "Compression...". The new small dialog-box that pops up lets you select which codec you want to use for compressing your captured video (it also provides a "Configure" button to fine tune the settings of the selected codec).
Unfortunately I think Premiere 6.5 does not save the compression codec into the Project Settings, so you have to re-select your prefered codec everytime you run Premiere (double check on that last one, just to make sure... I'm not 100% sure about it)
Regards...
PS. I think you should consider using a stand-alone capturing util for your captures (such as iuVCR or freeVCR or VirtualVCR). -
You are right, mate, Premiere 6.5 doesn't let you choose the compression codec in Project's settings.
Unfortunately i have Premiere 6.5.
Isn't there any easier way to choose the compression codecs?
For example right now i have Mainconcept dv codec working as default and then i installed Huffyuv codec installed afterwards. How do i make the Huffyuv as default codec? Do i un-install Mainconcept? -
Hmm... I think it lets you choose the codec, but it doesn't save it in the project, as far as capturing is concerned. But it does save the selected codec in the project when it comes to exporting the movie.Originally Posted by bayaraa_us
I really think you should consider using other programs for capturing your video. I know for sure that iuVCR saves every single setting, not only the selected codec, but everything else as well. The only glitch I get with iuVCR on my system (Win98SE, DirectX 9.0b and nVidia WDM drivers 2.13) is that every time I run it, it mutes Windows' sound and I have to re-raise the volume.Isn't there any easier way to choose the compression codecs?
I don't think you need to uninstall anything. It's just that Premiere doesn't save your selection. Try other programs for capturing video and then import it/them into Premiere 6.5 for further processing.For example right now i have Mainconcept dv codec working as default and then i installed Huffyuv codec installed afterwards. How do i make the Huffyuv as default codec? Do i un-install Mainconcept?
Regards...
A-B Switch Box?
By MourningStar in forum Newbie / General discussionsReplies: 8Last Post: 9th Mar 2010, 20:41 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 15:39 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 10:23 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:52
