Does anyone know if you can play a VCD on the PS2?
I created a MPG using the TMPeng and used Nero to burn it to a disk. When I put the disk into my PS2 it cannot read it. What am I doing wrong?
The PS2 will not play VCDs "out of the box".
The last time this was discussed on the forums, there was no work around to this. I am unaware of any new developments in this area.
Regards.
Michael Tam
w: Morsels of Evidence -
I'm not sure if it will play a VCD, but it should play a PSS movie. You'd have to reencode the movie though. Check this link out:
http://63.217.26.28/ps2/ps2_utils_graphics.shtml
I hope that helps.
