  1. Hello
    I have mpeg2 files created by panasonic'sw movie album se software that creates an *.mpg file--I would like to transcode the mpeg file to mp2 or m2v with an accompanying wave file.
    If I understand correctly, transcoding does not involve re-encoding and will not result in a degraded conversion.
    Thank you
    John
    Apr 2002
    The State of Frustration
    Try the demux tools in TMPGEnc.
    Hello.
  3. Banned
    Oct 2003
    Americas
    As indicated, it is called muxing (multiplexing) -combining audio and video streams or demuxing (de-multiplexing), splitting mpeg (program stream into separate audio and video streams). Look in Tools section for one that u may have (if u did not know it can do that) or grab the one u don't.
    Transcoding is considered re-encoding of mpeg stream (video portion at least)
  4. Thank you for the help. I will definitely look into tmpgenc and I went through the tools section but I must not have really understood what I was looking for. I will go through the list again and check my own software.
    Thank you both.
