I've tried to burn the movie Chicago about 6 or 7 times and it plays ok on pc and dvd player but the only problem is I can't get the video to flow. Its jerky and choppy. I'm using easy vcd 1.15. I have no other problems in the past with other dvds. I've tried everything that I know but still no go. Any ideas would be appreciated. Thanks![]()
Did you match the framerate of the source to your output?
"Art is making something out of nothing and selling it." - Frank Zappa -
If it gets jerky, just pick up ur player and jerk it in the opposite direction whenever it happens
Actually I found that the source is usually the culprit 9 outta 10 times.
yes thats right, 9 outta 10 dentists recommend a newer source.
You didnt say if it jerks on both pc and standalone. Also, is this the only one that does it? have you encoded another dvd the same exact way and does it have the same problem? -
what do you mean when you say I need to change the source and no I've never had this problem before with other dvds. Thanks for response
Check of the DVD is 23 or 29.97 frames a secDid you match the framerate of the source to your output?
Adjust output setting to match input frame rate
If there's keyframeing going on, match that rate also
Otherwise, result is a cyclical peterbation in all motion
Video jerky on MPC-HC
By bapalaps in forum Software PlayingReplies: 6Last Post: 13th Jun 2011, 18:02 -
Jerky Video.
By wasimismail in forum Video ConversionReplies: 27Last Post: 15th Dec 2009, 12:35 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
video still jerky
By milway in forum Video ConversionReplies: 15Last Post: 3rd May 2008, 17:01 -
Video is jerky
By arnie22112000 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 01:49
