HOW DO I EXTRACT AUDIO (wav) from an AVI file (Divx, it has an AC3 codec sound)
the movie is Enemy at the gates, it had problems with audio and I needed to get the AC3 codec....thanks in advance.
use the decompressor that comes with DVD2Avi. Then just get the audio by itself with TMPGenc
Computers
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
need help to play wav file
By adom in forum AudioReplies: 4Last Post: 7th Aug 2011, 11:47 -
how to cut a wav file precisely?
By Lastman369 in forum AudioReplies: 14Last Post: 6th Apr 2010, 23:21 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
.wav and .dts file problems
By bskies in forum AudioReplies: 2Last Post: 20th May 2007, 03:23
