Hi there, i was wondering something is there a way to tell where in your capture that you have droped frames, cuase i dropp 30 for every hour but i can't even tell, i mean i don't even think i should be droping any cause of the system i have, what are the services that you don't need in xp to run?
Perhaps you providing some / any information would help
like-
What capture card??
What capture format??
What source medium ( vhs tape, satellite, tuner) ??
What capture program??
What machine specs (cpu,ram,disks,XP home or Pro, etc)??
What you have installed (if we say turn off webserver and you host a site of the machine you'd be upset)
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 06:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 14:16 -
capturing software
By fabpozzi in forum Capturing and VCRReplies: 1Last Post: 23rd Oct 2009, 07:04 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 09:49 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 11:40
