  1. Does anyone know of a Mac program that burns cd and dvd image files for os 9? E-mail KungFu4425@aol.com if you could please.
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Apple Disk Copy, Roxio Toast, Charismac Discribe. I'm too lazy to email you, but in the future, you can go to your User Profile on this message board, and turn the "Always notify me of replies:" option on, so you get emails when people reply to you. Or, when you're posting a comment or topic, you can just check the "Notify me when a reply is posted" box at the bottom of the posting options for individual postings, if you don't always want to receive email notifications.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    i agree!
    the whole idea of these posts is for you to COME BACK and READ THEM!
    Mac OS 9 Burner. Toast all the way! Disk copy works too, but toast would be my favorite for that classic os
  4. Is there a trial versin of Toast cuse i spent all of mymone on the burner?
  5. Member WiseWeasel's Avatar
    Jan 2003
    No. But use Apple Disc Copy, it's already installed on your computer, in the Utilities folder, in your Applications (MacOS 9 ) folder. It's not compatible with all 3rd party drives, though, so you might end up needing Toast. If that's the case, You can find a very good deal on Toast 5 Titanium, which is compatible with MacOS 9 and should be available for under $40. Note: Toast 6 is NOT compatible with MacOS 9.
