Would updating your video driver help with capturing video? If so does anybody know any good video cards out there?
If you have one of the ATI All In Wonder cards, then yes. The video and capture drivers are designed to work together.
If you have separate video and capture cards, I don't think the video driver would cause much of a problem. Unless the video driver has a major DirectX issue. -
Depends on what you mean by "video driver." Most video cards make calls to DirectX either to display or capture video on a Wintel system, so upgrading DirectX if you have an older version will definitely and noticeably improve your system's performance for both display and capture of video.
If your video capture card is the one you're talking about, definitely upgrade to the latest capture driver available. Otherwise, as mentioned, upgrading the driver of a simple video display card that doesn't do capture probably won't change anything.
EasyCap Video Adapter Driver for Windows 7 64-bit
By Naymark.com in forum Capturing and VCRReplies: 4Last Post: 26th Mar 2012, 01:08 -
[SOLVED (?)] Opera 10.6 and higher, ¿ conflict with old video driver(s) ?
By El Heggunte in forum Off topicReplies: 1Last Post: 16th Feb 2011, 20:07 -
Mkv playback and video driver problem
By Tayyabghouri in forum Newbie / General discussionsReplies: 7Last Post: 4th Jul 2010, 11:06 -
Dead video card or driver trouble?
By Havola in forum ComputerReplies: 8Last Post: 19th Apr 2010, 03:43 -
Hardware\Driver problem crashes OS on video software
By Leorio in forum ComputerReplies: 18Last Post: 18th Oct 2009, 09:20
