Just bought first DVd burner.
If I don't have a DVD rom,are most of the DVd ripping/burning softwares designed so that you can play and burn using the same DVD-RW ?
"Today is only yesterdays tomorrow"
i believe it does. but you might want to do something else before you actually use it...TAKE IT BACK TO THE STORE FOR A REFUND.
many freeware progs equal to, or better than Xcopy...
DVD Decrypter
DVD Shrink
IMGTools
IFOEdit
VOBEdit
and you don't need all of them. matter of fact if you only wanted one prog (don'r know why since they are all very small in size and free) Shrink will do it all but burn. that you already have with your burner purchase. if not there are couple of free burning progs as well under the TOOLS section. or just get the first 3 and you'll have a complete system. good luck.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
