Hi,
I have create 20 chapters from home dvd movie in DVD WS.
Is that true i should always create 1 single MPEG 2 file into DVD WS if i want to contiune play to the end when i click any one of those chapter.
Because now i have cut & trimmed into many title and it will only play to chapter end then return to menu. If that's the case. I have to use other tools like Videostudio for editing and then output as Single MEPG file to DVD WS for chapters.
Thanks.
I would recommend that you use a single MPEG file and then set chapters within that single file.
If you chop up your project into separate MPEGs, and you make each MPEG file a separate chapter, then you'll only have the option of doing two things:
1. You can specify that when each chapter MPEG finishes, the viewer will be returned to the MENU;
2. As an alternative, you can specify that when each chapter MPEG finishes, the viewer will see a slight *pause* at the end of the chapter and then the next chapter will start to play (I don't care for this option.)
Hope this helps,
Jerry Jones
http://www.jonesgroup.net -
It would be great if i can do the 2nd option. Specify each chapter and pause for a second then will automatically start play next chapter. Since i have already chop up my project into many MPEGS . But can you tell me how do to do that in DVD WS?
Just wondering if there is any program i can combine multiple VOBs file into Single MPEG file ?
Originally Posted by Specialist -
Ulead MediaStudio Pro is a professional-level editor that will allow you to combine multiple VOBs to become a single MPEG file.
http://www.ulead.com/msp/runme.htm
Ulead VideoStudio is a consumer-level editor that will also allow you to combine multiple VOBs to become a single MPEG file.
MediaStudio Pro has the advantage of supporting AC-3 audio, however.
In DVD Workshop, you can right click on each separate MPEG in your project and a pop-up menu will appear.
When the pop-up menu appears, click AFTER PLAY.
Then you'll see two options:
1. LAST MENU;
2. NEXT TITLE.
If you select NEXT TITLE, then your MPEG chapter will play and then *pause* when it concludes - and then the next MPEG chapter will play.
Jerry Jones
Originally Posted by us_matrix -
Just to be clear, what JJones wrote about right-clicking is how you do it in Workshop.
Yes, thanks for the clarification.
I was writing about DVD Workshop when I wrote the info about the right-click menu options.
Jerry Jones
DVD & BluRay Menu + Chapter Creation Programs ?
By VideoFanatic in forum Authoring (DVD)Replies: 4Last Post: 2nd Oct 2011, 23:06 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
DVD Menu with Chapter and Menu Template.
By big-boo in forum Authoring (DVD)Replies: 3Last Post: 17th Mar 2008, 07:20 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36 -
Chapter Editing on Authored DVD
By radikal in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2007, 11:47
