well.......i have used the TMPGE to convert other avi. files to mpeg. Now the shit wont work and it says my file is unsupported or cannot be opened. when i go to the audio line the damn file will open though.It is only in the video line where it fucks up. Can anyone tell me what to do so that i can open the damn file, convert it, burn it and send it to my g/f. Thank you for your time everyone.
<font size=-1>[ This Message was edited by: VCDdummie on 2001-10-16 18:24:34 ]</font>
<font size=-1>[ This Message was edited by: VCDdummie on 2001-10-16 18:25:42 ]</font>
go to the Environment Options. then VFAPI tab. try messing with the DirectShow Filter... either make it a Higher Priority or try disabling it totally by unchecking it.
thanks for the help man, but hat didn't seem to work.......anyone have any other ideas?....thanks in advance
is there a time limit or file size limit in TMPGE???...the file i want to convert is 43 mins 25 seconds long and at 149,888 kb........please help me!!!!!!!!!!!!!!!!!!!!!
no size limit but what you could try is uninstalling whatever divx codec you are using and then reinstall it.
Hope this helps
mike
tmpeg - no sound on output file
By greytop1 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 17:20 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 07:23 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 14:01 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 05:31
