Hi, I was wondering if there is a inexpensive software/hardware i can get to capture excellent quality images from the TV to my computer that works fine with Window XP.
Since i have no TV in or any slots free ide like to use my USB2 or normal USB.
I have to do this fast becuase im managing a new gaming site which i have to update fast so anyone with any info, recommendations or experience with this type of TV imagery capture with winXP please let me know what is a good product i can get to do this.
Maybe you should have mentioned what you meant by inexpensive.
Hello. -
Heh, sorry bout that. I mean something between 50 to 100 bucks but for something so simple shouldnt cost so much.
Ive ordered WinTV Fm PCI cus i figured its cheaper and i could just remove the modem card or something else that isnt used.
Anyways thanks.
Recommendation of Video Capture Software for WinXP
By opey in forum Capturing and VCRReplies: 3Last Post: 4th May 2010, 03:16 -
Who makes the best USB2 capture card for under $100?
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 7th May 2009, 17:52 -
playing DVD images via USB port
By cbrylla in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2009, 14:08 -
Can I up from USB to USB2?
By jollyjohn in forum ComputerReplies: 16Last Post: 30th Aug 2008, 10:05 -
Is it bad to use USB 1 to external hardrive with USB2 interface
By edong in forum ComputerReplies: 5Last Post: 2nd Mar 2008, 04:50
