no matter which format i use, ac3 or mp2, sizzle wont recognize my audio file i want to add as background audio.
how do you use this feature? which app do u use to create background audio for sizzle??
thx
Results 1 to 9 of 9
tgpo,
could you give me a step by step how to?
I tried this with a 20 sec AIFF , and A.Pack
said it made a vaild AC3, but when I drop it into Sizzle
for use on the TOC background, it says it contains no audio
data, therefore cannot use this file.
I made it as a 0/1, no audio compression, 160 kbps,
and i've tried 1/1, 2/1, and 3/1 and no luck!!!!
What am I missing????
Here are the steps I take to produce an ac3 file.
Open A.Pack
Click File/New Batch List
Under Audio Tab
Change Target System to Generic AC3
Change Audio Coding Mode to 2/0 (L,R)
Change Data Rate to 192 mbps
Change Dialog Normalization to -29 dBFS
Under Bitstream Tab
Change Dolby Surround Mode to NOT Dolby Surround Encoded
Under Preprocessing Tab
Change Compression to None
Uncheck RF Overmodulation Protection
Then back in the lest side of the window I click the top select button and select my aiff.
Then click on the bottom select button and select my aiff.
Be sure that one is set to left and one is set to right channels. (Done to the left of the select buttons)
Then Click Encode. That's how I've always done it. -
the RF modulation and the Dolby I didn't mess with.
I'll give it a go tonight and post back.
tgpo, you are a god among gods.....
when I grow up, I want to be just like you!
old enough I should know better:
after running through your steps tgpo,
it still didn't work. Then, on a whim,
i tagged the file as an ".ac3" file,
which I didn't before, because I assumed
that Sizzle would read the header and recoginize it.
:P :P :P :P :P :P :P :P
silly me.
everything's grand now...
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 29th Mar 2012, 23:32 -
Looking for a video editing feature similar to "Shadows/Highlights" from PS
By vitwa in forum EditingReplies: 5Last Post: 6th Mar 2010, 17:21 -
"Encode video to audio duration" causes menu background jitter/no
By Fairy in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 8th Feb 2008, 16:02 -
"resume play" feature for dvds burned by dvd recorders (pioneer d
By barninga in forum DVD & Blu-ray RecordersReplies: 9Last Post: 19th Nov 2007, 02:11 -
No sound..."feature missing: DTS Decoding" ?
By vm711 in forum DVD RippingReplies: 2Last Post: 15th May 2007, 16:59
