I recently booted up my computer, and when XP starts, there is no desktop!!! I can see the desktop background(picture), but none of my icons, or the start menu.... I rebooted, and there is still no screen, not unless I choose to restart my system, and I am downloading something, then the start menu comes back for a quick second, then continues on with the restart process... Therefore, I have to command everything in my system with the Windows Task Manager.... Please HELLLLLPPPPPPPP!!!!!!
Results 1 to 9 of 9
try to boot in safe mode and if you can run system file checker in the run command, just type SFC. run scandisk too actually I think it's CHKDSK in xp, run it from command window
try this
hit alt+crtl+del and go to processes and then start new process and type in explorer.exe and see if it comes back up -
correct me if im wrong, but isnt that the "default" XP desktop presentation? Dont you hvae to actually go and say "Display desktop icons" and even then its not what you all are use to say in 2000.
i remember putting XP on my notebook and was like WTF, where is MY COMPUTER etc etc.
i ended up staying with 2000 but i remember it being like that initially -
Not entirely true. It only shows a couple Icons. The new Xp layout is Jacked IMO. I use the classic setupNo, the desktop is supposed to be automatically displayed in XP....
I tried this, and it acted as if something was working, but the desktop, or the start menu did not show up... 808, I tried running SFC, but it also did nothing...Originally Posted by nissmo300
You could try to boot from the Xp CD-ROM and "repair". I can't think of anything else without physically lookin at it
Also you might have a virus. Run a virus scanner if you can
Windows 7 desktop icons
By dfisher052 in forum ComputerReplies: 3Last Post: 30th Mar 2011, 10:55 -
windows 7 has shadowed text on desktop
By mysts in forum ComputerReplies: 2Last Post: 16th Oct 2009, 14:37 -
No desktop icon or Start menu with MPC Classic?
By mikehende in forum Newbie / General discussionsReplies: 9Last Post: 29th Mar 2009, 18:54 -
about desktop FLV player for Windows
By siluet in forum Newbie / General discussionsReplies: 16Last Post: 31st Oct 2008, 16:34 -
Windows 3.1 Desktop
By wulf109 in forum ComputerReplies: 3Last Post: 18th Jun 2008, 17:23
