Hi Folks,
I'm having big problems trying to copy dvdr's to my HD for burning, the problem seems to be from discs I get from others, had 4 types of media and no luck with any, yet they play prefectly in 3 dvd players. When copying or trying to re-do using for e.g dvd decrypter I get the following error-
Invalid NV-PCK:NV-VOBU-EA
I normally use anydvd/clonedvd or dvd decrypter , DVD2one then prassi.
If you need any more info from me to help solve the problem, please LMK.
Thanks for looking.
More than likely your DVD-ROM drive can not read DVDR discs (it happens). Since these discs work on standalones you know that there's nothing actually wrong with them. Best bet, get a new DVD-ROM drive.
You can try to test them out on another PC's DVD-ROm to double check, but the standalone kind of took care of that. Sorry. I'd recommend the liteon 166.
Upside, as these are DVDR (ie. DVD5 discs) once you can read them you can just do a 1:1 copy with DVD Decrypter if you must, drag and drop
hertderg
are they dvdrs? if so drag and drop to hdd within explorer...don't need any progs.the problem seems to be from discs I get from others -
Thanks for the suggestions guys.
I don't think it's the DVD rom drive as I can read dvdr's that I have copied myself,and also read them from my 105, the problem only seems to be with copied dvdr's that I have recently had from others. First I thought it was the disc but various media has been used from various people which suggests it's not the discs.
Sometimes the disc will copy until the last 60 seconds end it throws up the error box.
Any other ideas?? -
It could well be the way they have been burnt, I asked a mate who also has a 105 to try and copy them to his HD and he had the same problems as me.
Is there anything else I could try to copy these?
IMGburn 2.5.1 copying problems
By NickiMitch in forum DVD RippingReplies: 1Last Post: 7th Jun 2010, 08:58 -
Problems copying CDs on Mac
By Nilfennasion in forum MacReplies: 3Last Post: 3rd Jul 2009, 08:15 -
Best DVD to DVDR Copying Software
By mattstan in forum DVD RippingReplies: 1Last Post: 18th Aug 2007, 09:24 -
Problems copying a home-made DVD
By jj1807 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jul 2007, 14:20 -
Anyone had problems copying Dvd's with HP drives?
By Blumphf in forum DVD & Blu-ray WritersReplies: 53Last Post: 31st May 2007, 20:40
