  1. Hey.
    I bought a 128mb games card but I think ive been ripped off. How can I check it is actually 128mb?? I want to make sure it is actually the games card I bought.
  2. Banned
    Apr 2001
    Calgary, Canada
    Assuming you are running Windows XP and have DirectX installed, look for (and the run) the following file: C:\WINDOWS\system32\dxdiag.exe
    Up pops a diagnostic dialog. Go to the Display tab, and you'll see all sorts of stuff about your video card (atleast you should), like this (for my laptop):
  3. Thanks! Brilliant
    How do I post an image of mine up ??
  4. Banned
    Apr 2001
    Calgary, Canada
    Try this... (let's see if it works)...
    Look at the B, i, u, Quote, Code, List, List=, Img and URL buttons above the reply window
  5. Member Devanshu's Avatar
    May 2003
    Sort of related...not to take over the topic or anything, but how can I add multiple images from my HD? I know how to do one...
  6. Okay well the image isnt on the net so i cant exactly link to it, but on direct x diagnostics it does say 128mb. Could someone have tweaked something to make it say its 128mb card? But maybe only 64mb?
