I am burning an avi file to VCD. The video source is ready. I've frame served it in VirtualDub, and its ready for TMPGEnc.
I have extracted the audio in VirtualDub as a Wav file. What do I do with this audio? What should I convert it to and what is the best (easiest) program to use? How many Hz should it be?
Or shall I just use the Wav. audio in TMPGEnc and multiplex that???
Unless you are going to make some non-standard VCD, save yourself a step and load both the audio AND the video streams from the frameserver into TMPGEnc -- It will automagically detect both streams for you. Let it encode to mp2 @ 44Hz (for VCD).
The only time I extract the audio to a wav file and encode separately, is when I'm going to do ac3 audio for my DVD's
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
