Hello
I have been recording tv shows on my panasonic hs 2 dvd recorder. I perform all of the edits on the hard drive then I transfer the show onto a DVD Ram disc. After I have transfered the shows to a ram disc, the ram disc is inserted into my Panasonic Lf d521 computer ram/dvd drive..
I am able to open the programs on Movie Album SE. Movie Album SE allows for the file to be exported as an MPEG2 file with the extension *.mpg.
My Adobe Premiere 6.0 does not accept *.mpg files. I can load the file into the preview window, after that the entire system freezes. If I rename the extension *.mp2, Adobe Premiere does not recognize the file.
I also have Vegas 4.0+DVD. Vegas accepts *.mpg files, however, DVD architect requires that the file be re-encoded. After the re-encode, the quality drops considerably.
Rather than purchasing yet another DVD authoring software, I am looking for a way to avoid re-converting the mpeg stream.
I found that Hueris software makes a plug-in for the Adobe Premiere called ConnexIT [price of software $79] which allows the editing of the Ram recorded VR files. If I understand the plug-in correctly, Adobe will edit in the VR format and then I can encode via the Pinnacle DC2000 for my mpeg file for DVD authoring. Anyone on this forum familiar with this software?
Without purchasing a plug-in or another DVD authoring software, can I effectively edit and author a DVD without multiple mpeg conversions? Or is a different DVD writer or plug-in needed?
Besides the cost of another software purchase, I tend to believe that the Pinnacle DC2000 capture board will offer better mpeg converions than software based--am I mistaken?
Thank you
John
Results 1 to 1 of 1
Are you not able to bypass Macrovision content on DVD for 3minutes
By ledishis in forum DVD RippingReplies: 2Last Post: 10th Dec 2011, 12:50 -
Copy Protection on a DVD-R disc - how to bypass?
By nerys in forum DVD RippingReplies: 25Last Post: 4th Apr 2011, 23:00 -
RAM usage drops drastically after encoding
By Moontrash in forum ComputerReplies: 2Last Post: 2nd Dec 2010, 21:16 -
Converting DVD-RAM to DVD WITHOUT re-encoding?
By MePerson in forum Authoring (DVD)Replies: 13Last Post: 27th Jun 2008, 13:38 -
VHS to DVD. How to bypass error message?
By 4194 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Jun 2008, 14:58
