Hi ive got a choice of some ritek go3 at between 60p and 70p or a batch of Ritek GO4 at 95p-110p, i know the GO4 are slightly better, but does it justify the extra money, i have a Nec ND1300 and both the discs are -R, im also trying to lower the cost of my dvd projects, at the moment im leaning toward the GO3. Any comments appreciated, thanks all.
14 Minutes verus 29 minutes says it all.........
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
it always come down to if one has more time than money, doesn't it
elmotheteapot
did you know that the 3s and 4s are of different speed (accounts for price difference)? could not determine that from your post. go with the 3s since $$ is an issue. at the extremes it's almost 2 blanks to 1. -
At the end of the day im not very fussed about speed, price is the factor and quality, so i guess its the GO3 nothing else seems to match the quality in its price range, the discs are DATASAFE RITEK 1x-2x.
