OK i've never captured anything from vhs to my pc before so let me explain what i would like to do.
Im in the uk so the vhs is pal.Theres about 6 - 8 episodes of shasta mcnasty on tape that i recorded.I would like to put these to dvdr so they will last alot longer than tape.
I would like to convert the audio to dolby 2.0 192kps 48hz.The video encoding part with CCE i should be able to figure out as i use that when backing up a dvd.
So how would i go about doing this ?? .. oh if possible i would like to capture/encode to progrssive without deinterlacing, but if not i'll encode it interlaced, no big deal.
I have only about 20GB of room on one of my drives to do this, i have a Leadtek Geforce 4 Ti 4200 My Vivo Edition,it has video in and out.
I have adobe premiere 6.5, virtual dub 1.3 and 1.4. Program wise i get or use what ever, but i am looking for nice good quality.
Big 3 User.....
PAL User....... -
I capture with a similar card (ASUS 9180 GeForce MX440-VIVO) and VirtualDUB. But, man, VirtualDUB has reached version 1.5.8 by now. Get an update; it's more than worth the download (600kb).
Since you are tight in space, it's critical which codec to select for capturing.
If you have a slow PC (<2.4GHz
) then you must use hufyuv 2.11 as it's fast - and high quality. I used to use this and still do mostly.
If your CPU is faster than 2.4GHz, you can use DivX 5.1 in Constant Quality mode and a setting of Q=2. Also, in additional settings, select a keyframe interval of 5 (meaning 5 Keyframes per second). This will help in editing and further improve quality. Also, in speed mode, select fastest.
This DivX setup will give you small files (~5Gb per hour) with excellent quality. The hufyuv alternative will allow you to capture a single episode in the 20Gb.
VitualDUB is sufficient for trimming and I don't use Premier mostly.
I would recommend that you capture at full PAL resolution (720x576) and then, while trimming with VirtualDUB, pass video from a "blur" filter and a resize to 352 x 288. VHS doesn't really give you a better resolution. You can verify this by viewing in VirtualDUB with the output window in 2x resolution. Not much difference to be seen and a whole lot of difference in bitrate.
Encoding the 352 x 288 video in CCE would require an average bitrate of no more than 1800kbps and ultra low bitrate QM Coefficients.
A Dolby Digital encoder is tricky to find. And I don't think it's worth the trouble. MPEG-2 at 192kbps is far sufficient for TV broadcast. And if it's mono, 128kbps is more than enough.
The above are general guidelines. Feel free to ask for any clarifications.
Good capturing!The more I learn, the more I come to realize how little it is I know. -
To convert the sound you can use SONIC MyDVD 5.0 DeLuxe version. It will convert the sound to DD 2.0 192kbits.
http://www.sonic.com/products/mydvd/default.asp
What format for VHS to HDD to TV? Playing off a HDD instead of DVD?
By Rudyard in forum Video ConversionReplies: 10Last Post: 6th Aug 2009, 20:46 -
Want to get home video pal VHS onto my pc HDD, recomended capture card?
By ha9981 in forum Capturing and VCRReplies: 6Last Post: 26th Mar 2009, 15:34 -
VHS capture to HDD
By bcags7 in forum Capturing and VCRReplies: 2Last Post: 17th Oct 2008, 14:59 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38 -
Ghosting on PAL VHS CApture
By tumaz in forum RestorationReplies: 30Last Post: 4th Oct 2007, 16:59
