hi
is there anything that will eliminate the odd bad square blocks in the film, as they are some times left in after running the film through mp3 freeze and also tried in the 1.5.8of v-dub, after removing the bad frames?
many thanks 8)
I'm assuming you already know how to work w/ mp3 freeze since you mentioned it. You can always take out the bad frames w/ the blocks in it.
hi
i've used mp3 freeze, after removing the bad frames some time u still get the odd blocks, if u can remove these can u give me some direction on how to
many thanks
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 13:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
