I have a Xvid avi movie that I am trying to convert to dvd. My problem is that I do not get any sound. I have separated the wav and video while encoding using TMPGEnc, and have extracted the wave sing VirtualDub. The wave file that i get from VirDub comes out with no sound when I try to compress it it says it can not. Is there a new Audio codec for xvid that I can use. Thanks
hi
the xvid codec may be your troble if it's not installed, to find out if the codec is installed in your pc, download g-spot, and load the film and this will tell u if the codec is installed. I've had problems seperating the audio and video streams, using two diffrent tools. i found loading the both streams into tmpge and converting with less problems.
hope this helps -
Smells like AC3 sound. Do you have the AC3 filter installed?
XviDs are either MP3, OGG, or AC3. They could be something else but generally are one of the 3. VBR MP3 presents its own problems, but VDUB should warn you first.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
VDUB can not extract a WAV file from AC3 sound track. You have to extract the AC3 track, then fix the header, then go from there. If it's a OGG soundtrack and you don't have the OGG-Vorbis package then you wont' get anything either.
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 09:01 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
