Hi All,
I currently use Creative PlayCenter to extract the audio from all my THAI VCD's. But recently the few VCD's that I've just purchased doesn't even play on Creative PlayCenter or WindowsMediaPlayer..
Could it be because it's a SVCD?
**But it does play on Cyberlynk - PowerDVD! Sad thing is PowerDVD doesn't allow me to rip audio!!!
So question is --- Is there a software out there that will allow me to extract the audio from SVCD, just like Creative PlayCenter?
Thanks in advance!!
Lai
I can think of a few options:
1. Use TMPGEnc. Use the demultiplex option to extract the audio from the (S)VCD mpeg file (I know with VCD you could just rename the *.dat file to *.mpg - not sure about SVCD though).
2. Load the mpeg from the (S)VCD into virtualdubmod, and then use either the Save WAV option or the demux option to extract the audio (under stream list)
3. Use an application like Total Recorder to make a digital copy of the sound while theVCD plays in real time.
Extracting audio from flv
By Mike99 in forum AudioReplies: 30Last Post: 22nd Apr 2011, 08:31 -
Extracting Just The Musical Audio
By niteghost in forum Authoring (VCD/SVCD)Replies: 9Last Post: 6th Jan 2011, 05:09 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 16:22 -
Extracting Music from Audio CD
By prayami in forum AudioReplies: 4Last Post: 4th Aug 2008, 17:59 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37
