Anyone have a solution? I'm trying to multiplex video and audio files but tmpgenc won't open the wav. TIA
I don't want to re encode the entire video for no reason. I just want to combine the wav and my mpg file.
Combine them for what? I don't think you can combine them for anything without reencoding. -
First, convert your wav file to mp2 using TMPGEnc, this way you will not have any sync issues.
Second set TMPGEnc's Wav filter to a higher setting through the options/environmental.I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H -
Why do you want to multiplex wav and mpeg-video? If its for a DVD, let the authoring program do it.
boy that just went completely over my head. I just started dvd authoring for some reason I didn't even consider that. Guess I'm just too used to making vcd/svcds. Thanks for the help.
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 10:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
Nero won't open .mp4 file
By ChickaJane in forum Video ConversionReplies: 8Last Post: 21st Aug 2007, 23:38 -
Cannot open wav files in Tmpgenc
By deadlycow in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2007, 02:54
