How does MPlayer decode compare with QuickTime decode?
I've been using QT decode ever since the option was available in ffmpegX and it has converted every DVD I've tried with perfect sync.
Yesterday I tried MPlayer decode with various settings and it never gave me an in sync result. Has anyone had success with it?
Using mplayer to decode is useful when you need to add subtitles to a VCD/SVCD/DVD, or, when your source is a VIDEO_TS folder. mplayer is frame-based while QT is timecode-based.
so if you process the video_ts folder with mplayer you should end up with in-sync files?
Speaking of QT Decode... Now that I've updated to Panther and QT 6.4, the MPEG-2 decoder doesn't work. I can't read MPEG-2 in QT nor will ffmpegX work with the QT Decode option checked. I looked on Apple's site and it says I can go to the Apple store and download the update for it to work. When I go to my account, there is no option to download the update. Anyone know of another place I can get it?
Decode LG HB405SU
By ShaunA in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Jan 2011, 08:43 -
DivX and XviD decode only
By CSULB71 in forum Software PlayingReplies: 10Last Post: 20th Apr 2010, 09:33 -
Question about decode
By Russo in forum Newbie / General discussionsReplies: 7Last Post: 16th Apr 2009, 12:30 -
What is being used to Decode?
By tb582 in forum Video ConversionReplies: 12Last Post: 9th Sep 2008, 15:15 -
Decode with Quicktime
By Nekesu04 in forum ffmpegX general discussionReplies: 2Last Post: 13th Jul 2007, 16:25
