I posted this following thread into a previous post that can be found further down the page. Nonetheless this can be a helpful post for those of you that are looking for a HDTV for your HTPC or general use. This info applies to the 60' model as well. I have no war with RCA, this is by magic (internal) a HDTV, but you will disappointed;as I am if you think that this is going to work for an HTPC sys.
Well here is the dismal answer for my problem. this is a post for all that are interested in following this thread. This is from the horses mouth, RCA's tech dept.
This unit is HD only in it's final resolution! The highest input available thru any means is the DVI-HDTV. Guess what it is only 480i capable. According to the very knowledgeable person at RCA the component, composite, S-vid inputs are all lower ( in the 180 line range). BUMMER. RCA takes the available analog or Digital signal and processes it up to 720 to 1080 range by internal algorithyms to a final max res of 1920x1080. They told me if I want to have a true 1080I signal in I have to purchase an external converter. Gee this is true magic. Take a 1080 input siganl and convert to 480 so you can get 1080 on the screen????
In short this isn't a true HDTV - so forwarned u b. Stay away from this one if you want to input a HD signal from you're HTPC.
Jeff
Results 1 to 1 of 1
Rca hdtv
By wulf109 in forum DVB / IPTVReplies: 1Last Post: 16th Mar 2012, 22:40 -
HDTV Technologies - LED, LCD, Plasma and DLP.
By prankstare in forum DVB / IPTVReplies: 0Last Post: 13th Aug 2009, 01:50 -
Where to buy good HDTV's?
By Nitro89 in forum Off topicReplies: 5Last Post: 13th Nov 2008, 14:06 -
WHAT TV SHOULD I BUY? LCD vs. PLASMA vs. DLP TVs...
By jimmayor007 in forum Newbie / General discussionsReplies: 3Last Post: 1st Sep 2007, 18:09 -
My DLP HDTV accepts 1080i through component input, vid quality = HDMI?
By Denvers Dawgs in forum Off topicReplies: 4Last Post: 9th May 2007, 14:16
