  1. Is it possible to convert VOB files to either MP2 or AVI. If the answer is yes, how does on go about it?
    Regards
    Ray
    Apr 2002
    The State of Frustration
    To convert it to an AVI, load it into Virtual Dub mod.
    To convert it to a MPEG, load it into Virtual Dub and frameserve it to TMPGEnc. Sometimes TMPGEnc will accept VOBs.
    Hello.
  3. I've always copied the DVD to my HD and changed the .vob extension to a .mpeg extension and imported into my video editing software.
    Geronimo
    Dec 2002
    VOB's aren't MPEG's per say. Your software is probably ignoring the extensions and reading the headers (which you didn't change). It's the same way a .ogg file will play when there's no registerd application for the extension.
    There's no way to convert a VOB to an MP2/AVI. You have to encode the vob to get an AVI.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  5. First demultiplex using VOBEDIT ->Demux:
    If you want MPEG-2 then multiplex .M2V and audio in TMPGEnc.
    If you want AVI use then load the .M2V file and your audio into TMPGEnc->File->Output to AVI(make sure to set frame for interleave to "1") .
  6. Thanks for all your inputs. Shall try them out.
    Kind regards
    Ray
