I may be doing exactly the right thing, but I would like to validate it.
I am capturing VHS video into MPEG2 via a Sony Vaio desktop in about 700MB chunks (about 15 minutes). I then edit using Screenblast Movie Studio 3.0.
After editing I add other edited chunks into MS, add transitions, etc to create a clip of about an hour.
The next step is to author using TMPGenc Author, to add chapter points and then burn.
Does this sound correct?
Thanks,
Allen
look at lordsmurf's website at www.lordsmurph.com for some tips. I dont believe that you have an ATI card, however, you should be able to get enough information to help you.
Personally, I am a desktop recorder guy (E30). They, IMO and others, offer the best final product.
Dumb question? Analog or digital settings when recording from tv?
By BonnieW88 in forum Capturing and VCRReplies: 4Last Post: 9th Mar 2010, 13:38 -
Portable PAL analog (yes, analog!) television set
By stuey123usa in forum Capturing and VCRReplies: 0Last Post: 22nd Jun 2009, 20:23 -
Urgent Question Sony CCD-TRV438E Hi-8 Analog Camcorder
By Shaga in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 20th Oct 2008, 14:32 -
Analog to DV Tape vs. Analog directly to computer
By jlorelle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 7th Sep 2008, 10:45 -
Home Theater: Analog and Digital audio cable question - impedance
By radiowhiz in forum AudioReplies: 4Last Post: 31st Jul 2007, 00:32
