I have an mpeg that's 905MB. I would like to burn it as svcd or vcd. Would I convert it and then split it so it will go on two discs or do I have to split it first?
What program will covert it and which will split it?
thanks
MPEGs are a pain to split, as I've yet to find an application that relieably and consistently can perform this trick. If you have to reencode, you're better off encoding in 2 passes, using Source Range (TMPGEnc).
/Mats -
or buy some 90min or 99min cdr... this just might fit on a 90 min cdr and would def fit on a 99min cdr. Splitting mpeg is a pain, quite often even tmpgenc wont work.
A lot of people seem to reckon that Womble MPEG-VCR can do decent job of splitting MPEGs - more reliable than TMPGEnc in terms of creating A/V sync issues etc..
I've never tried it... just passing the info on!
cheers,
mcdruid. -
Tickle: Don't hijack a thread. Your problem isn't realted to the thread topic, start a new one with details.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Converting MOV to MPEG-2 File
By cyberboy in forum Video ConversionReplies: 5Last Post: 16th May 2009, 18:39 -
Converting AVI file to mpeg 2 question.
By ingeborgdot in forum Video ConversionReplies: 17Last Post: 7th Nov 2008, 21:49 -
Converting and splitting 2GB MPG file
By mohalfares in forum Video ConversionReplies: 3Last Post: 2nd Sep 2008, 13:47 -
Converting EyeTV MPEG file
By lkearl in forum ffmpegX general discussionReplies: 8Last Post: 7th Feb 2008, 11:58 -
Converting audio from a mpeg file to a mp3 file?
By hrace in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 17:15
