Hi
Back again
Cant use tempgenc author with win98 - Had to load spruceup
But can i heckers like gat my audio file in
Tried the help files but they are as much use as a fart
in a spacesuit
Is there any kind person out there that can explain to a laymen in simpl terms how to import an m2v - vid file and its ac3 audo file into spruce up
All i'm trying to do is get them back together as a unit to burn them on a dvd - i assume as vob files
Unless there is a more user friendly prog that you canadvise me of
Once again many thanx in anticipation of an early answer to you guyz who have always rising to the occasion with my queries
Tell you what if i ever meet any of you i'll buy a pint
hows that for generosity
regards
Rename the audio file to the same name as the m2v file but with extension .ac3. Something like this
video.m2v
video.ac3
and open the video.m2v in Sprucup and it will automatically open the ac3 file.
If it doesn't work try TMPGEnc DVD Author or DVD-Lab.
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 21:59 -
How will an MP3 audio file will compare with a AAC audio file?
By ConverterCrazy in forum AudioReplies: 6Last Post: 31st May 2011, 02:01 -
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 06:01 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
