I have a Sony Dru510a and up until recently I had no problems burning. Now the buffer is around 5% and the device buffer bounces up and down actually they both do, and the burning speed jumps from like 0.3 to 3.3 and up and down. Both buffers used to be all the way up and a Ritek G04 would take about 15 minutes to burn. Now it takes 30 minutes to an hour. Is there anything I can do to fix this problem? Buy the way my firmware is 1.0D
I had the same problem with 3.1.7.0
I went back to 3.1.6.0 and the its solved now...You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
dvd decrypter
By dr strange in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 14:11 -
burning a dvd with dvd decrypter
By shashgo in forum Authoring (DVD)Replies: 1Last Post: 29th Dec 2008, 17:34 -
question about DVD HD Fab Decrypter/Burning
By Bamahusker in forum DVD RippingReplies: 22Last Post: 19th Nov 2007, 11:33 -
Burning speeds and DVD Decrypter...
By Nilfennasion in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 04:32 -
Problem burning to Verbatim DVD+R DL with DVD Decrypter
By spyder67 in forum Authoring (DVD)Replies: 6Last Post: 14th May 2007, 17:49
