  1. I am trying to print a dvd cover (for a rectangle case) with both back and front in one picture, but I cannot fit it all on one page. It's very close though...2 or 1 centimeters or so. Now, I can easily see it's possible to fit it on one page, but the margins prevent me from doing so, even if I set them to the lowest possible number.
    Can somebody tell me how I can accomplish this task?
  2. Have you tried saving the image as like a JPG or other image format then using a program like CoverXP (google search for a download location) to print it out?
    I know my printer has problems with margins in programs like Word but with a DVD printing program it seems to operate fine.
    May 2003
    canada
    I had the same problem.
    Solution: Switch to legal (8.5"x14.00") size paper.
    Works like a charm.
    kiki
  4. Member gooberguy's Avatar
    May 2003
    WNY, USA
    i had the same problem, and 14 posts in my thred couldnt solve it, you people solved it in 2 posts. Wow. Thanks a bunch!
  5. ok, thanx kiki, everything works now =)
