If you have your source on one drive and encode to another drive it should speed up the process. I'm wondering if someone can give an idea of how much difference it makes. I'd consider getting a second drive if the difference was significant.
encoding is highly cpu bound .. hdd speed makes bugger all difference.
Hi Michelle,
One more thing to consider there..
If you encode over a network, it will approx double your encoding time.
I have my sources accross my network (two pc's via built-in LAN) and I
encode my 2nd pc's .AVI files while on my main pc. This slows up a lot of
HD activities. If I were to encode my sources directly on my main pc's HD,
things would be that much faster. Maybe I'm exagerating a little, but it
sures feels like I'm waiting forever - most, if not all my sources are over
a LAN HD.
If you have LAN turned on in your BIOS, and you don't have two pc's connectd,
you might benefit somehow, by DISABLING it in the BIOS. Might help out in
the capturing anyways
-vhelp 2083
[FFmpeg] Up encoding speed for wmv's
By Klagar in forum Video ConversionReplies: 5Last Post: 24th Jan 2011, 13:00 -
Video encoding speed slower than previously
By genak in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2010, 17:23 -
SSD (Solid State Drives) for Encoding?
By ajgoyt in forum Video ConversionReplies: 6Last Post: 8th May 2010, 14:31 -
decreasing encoding speed with mencoder (mplayer)
By sammy82 in forum Video ConversionReplies: 2Last Post: 1st Apr 2010, 23:58 -
can you speed up encoding with ripbot x264
By zerocoool in forum Video ConversionReplies: 6Last Post: 26th May 2008, 21:07
