Question for those that use ReelDVD...
I would like to use the application mainly for converting WAV audio to AC3 audio (no video). I'm aware that there is an LE and a Studio version, and before making a purchase, would like to understand how straightforward the process is and what versions support AC3. I've looked at the Sonic website, and of course couldn't find this info.![]()
I've tried a couple of apps that support AC3, and found that I had to use their capturing & authoring process as well. Essentially, I need the WAV-to-AC3 process to be a stand-alone feature, and not have to be tied into the apps other procedures.
In case your wondering, I've already tried BeSweet, and can't use it due to compatibility issues. I appreciate your feedback.
REEL DVD costs more than Vegas w/ the ac3 encoder pack and does less in the way of encoding audio for ac3 (you can surround pan and such in vegas) plus vegas supports Dolby AC3 EX
or you could buy acid with the ac3 plugin also - for even less ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
the ac3 plug in pack for acid and vegas is here http://mediasoftware.sonypictures.com/Products/ShowProduct.asp?PID=772
or you could also buy vegas + DVDA for about the same cost ... comes with the same ac3 encoder plugin built in to vegas ... you dont need to use DVDA"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You probably want Sonic MyDVD Deluxe 5 which does AC-3 encoding. You can downloaded it and then register it for $70 or for $100 you can purchase the step-up version called Sonic MyDVD Studio Deluxe 5 and for the price of $100 you actually get it shiped to you on DISC plus for the extra money you get RecordNowMax which is a great DVD burning program.
Anyways both do 2.0 AC-3 encoding.
I haven't tried it yet but I'm thinking of buying the $100 Studio Deluxe version.
Thanks for the replies.
I still do need info regarding ReelDVD. I'm able to purchase a used copy at a good price, thus my reason for focusing on its audio encoding capabilities. Also, my encoding needs are basic 2-channel AC3. -
well - i think (pretty sure) that ReelDVD's ac3 encoding isnt a "stand alone function" , its been a while since i used it...
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
stereo loss after converting from wav to ac3
By Driber in forum AudioReplies: 8Last Post: 9th Sep 2009, 03:29 -
Converting WAV to AC3 - sound loss
By MackemX in forum AudioReplies: 10Last Post: 19th Mar 2009, 16:15 -
Hiss removal from AC3 file without converting it to WAV?
By Turbo Sensonic in forum AudioReplies: 21Last Post: 7th Jul 2007, 07:18
