I like editing commercials out of tv capture AVI files.
After doing so in Virtualdub, I save the AVI using direct stream copy for both audio and video.
BUT, I get a audio / video sync problem that seems to be accumlative. The beginning of the AVI is fine, but the end of it (usually 90 minutes later) is out of sync by about a half second or so.
Is there a better way to edit AVIs? Is this problem unavoidable?
Please don't jump down my throat. I've tried searching the forums for an answer already.
Thanks in advance.
I'd rather die of thirst, than drink from the cup of mediocrity.
Start capture when commercials end-stop capture when commercials begin. Trim off ends and then join. Then if you want, compress the file with codecs of your choice.
Question about Firewire>USB (Same end result)?
By sj022698 in forum Capturing and VCRReplies: 1Last Post: 24th Apr 2011, 23:37 -
Editing Commercials
By Jacks_Daddy07 in forum EditingReplies: 2Last Post: 18th Oct 2010, 23:09 -
Capturing From VHS Via VirtualDub Produce Strange Result
By max20d in forum Capturing and VCRReplies: 0Last Post: 8th Oct 2010, 22:55 -
Does a middle encode harm the quality of the end result?
By PuzZLeR in forum Newbie / General discussionsReplies: 8Last Post: 21st Jul 2009, 19:26 -
Burn DVD using DVDFab end result one file in iTunes?
By Kramer620 in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:26
