Before I lay down $700.00 for Premiere I have one question ..................
.........will it do standards conversion from Pal to NTSC. I don't want to fool with script based software like Avisynth.
it does but not well
Not to my knowledge in Premiere 6.5. I actually spent hours trying to convert my PAL footage to produce an NTSC DVD.
I managed to do it, although I am not fully satisfied with the end result quality.
No need for Avisynth though. I tried Avisynth but it did not give better results. Probably actually worse than using the Premiere functions.
I don't know about Premiere Pro. Maybe someone else can tell us. I am also about to shed $400 for the Adobe DIgital Video Collection. -
after effects does a (MUCH) better job (or vegas (very well) or couple other apps - well a few anyway - some are real good)
. Is there a site or a guide explaining how to do this conversion with After Effects somewhere? Can you do it with the SE version or do you need the PE?
Thanks -
http://www.adobe.com/support/techdocs/c5fa.htm (good info!)
guides found on google also (some i found didnt make a lot of sense) -
vegas uses super sampling (very powerfull feature to create New frames via interpolation), you find this on pro software like fusion and time master and shake ..
ae uses the tried and true method of field seperation - but following thier advice gives pretty good results ... same method was done for years in million $ hardware .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
How to change NTSC to PAL in adobe premiere elements 7
By jarko in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2009, 20:28 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
Premiere PRO - NTSC DV to PAL MPEG output
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2008, 12:06
