This may be a little off the wall.I use 98Lite Pro which allows me to install Windows 98/SE without a bunch of stuff like Internet Explorer etc... It also allows me to swap the Win 98SE shell with the Win 95 shell for a stability and speed increase. The problem is with the Win 95 shell DVDShrink 2.xx-3.xx will not run, though the earlier DVDShrink 1.xx will. Has anyone got any ideas or does anyone even have the faintest idea what I am talking about?
I do have the faintest idea, since a friend of mine was one of the developers of 98Lite.
I'm going to shoot an email over to him with a link to this post - don't know if he'll respond quickly, though, as he usually has a million things going on at once...
I've never tried running Shrink under 98Lite, so I don't have any advice for you...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Hi.
GKar, the following is a quote from dvdshrink, the developer.
Win98/2000 problems
I think most of these problems are related to fact that DVD Shrink is compiled with Microsoft Visual C++ .NET version. I may go back to using Visual C++ 6.0 (which was used to compile DVD Shrink 1.03). DVD Shrink does require ASPI drivers (wnaspi32.dll) installed if running on Win95/98.
http://forum.digital-digest.com/showthread.php?s=&threadid=25207
This might mean you'll have to wait and see if the next release will fix your problem.
But if you still want to try and make it work, here is a link to the "Force ASPI" download, with easy installation:
http://radified.com/ASPI/forceaspi.htm
You could also check the following list of files used by DVD Shrink (on XP/2000 systems though):
http://www.dvdshrink.info/processes.php
I hope this helps. -
Thanks! I have ASPI 4.60 (1021) installed. I believe you might have hit on the problem in the way it was compiled. If the ***
GENIUS
*** behind DVDShrink does his coding in the older C+++ on any newer release and it works I'll be shittin golden bricks!
"...I'll be shittin golden bricks!"
If it ever happens, could you send dvdshrink and myself a few of them?
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 09:53 -
Head swap in a video using Sony Vegas Pro - is it possible and how?
By Nicole2011 in forum EditingReplies: 6Last Post: 19th Feb 2011, 16:52 -
IMGBURN shell ext query
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 22nd Nov 2010, 10:21 -
Problem to swap one subtitles to another
By mangus37 in forum SubtitleReplies: 7Last Post: 2nd May 2010, 03:52 -
need to swap images in and out via button states in DVD Studio Pro 4
By theMonseignuer in forum Authoring (DVD)Replies: 2Last Post: 26th Jul 2008, 11:06
